WILL 8N FORD OPERATE 5 FOOT BUSH HOG?
J. Broome
03-08-1998 08:25:51
Will 1948 8N Ford operate a 5 foot bush hog, if so, what type or brand would I look for?
Rick (PA)
03-08-1998 16:27:39
 Re: WILL 8N FORD OPERATE 5 FOOT BUSH HOG? in reply to J. Broome, 03-08-1998 08:25:51
: Will 1948 8N Ford operate a 5 foot bush hog, if so, what type or brand would I look for?
Sure you can. I have a 5ft bush hog myself for my
8-N. It is a medium duty unit with stump-jumper blades
and an over-run clutch. Last summer I mowed my
feid that had not been for a couple of years.
It was tall and thick. Took my time in 1st gear
worked fine. Lower stuff can mow in 2nd. Hoope this helps.
Ryan West
04-29-1998 08:21:32
 Re: Re: WILL 8N FORD OPERATE 5 FOOT BUSH HOG? in reply to Rick (PA), 03-08-1998 16:27:39
An 8N can handle a 5 foot Brush cutter easily but you must use an overrunning clutch. This is because the 8n does not have live p.t.o..
John in IN
03-08-1998 11:27:44
Depends on what you want to mow. 5 ft is a good size, brand depends on what you are mowing and how much you want to mow. Heavy stuff and more than a few acres, I'd go with a name brand. I can't criticize my Woods. If you're only cutting a few acres of grass afew times a year, you can probably get almost any brand. Be sure to use an overriding clutch.
John
chris
03-08-1998 09:30:53
it depends on how tall and thick the stuff you are cutting. I have a 32 hp. ford that I use a 5 ft. cutter on in thick stuff it can be a big pull hope this helps Chris
