Tractor Talk Discussion Forum
OT: Street Rod Speedometer
Jason1(Pa.)
05-11-2008 10:04:00
I have a street rod I got last summer. I notice that the speedometer reads 10mph faster then what you are going. How can I solve this problem. Anyway to get the calibration right? Thanks
dave guest
05-11-2008 19:43:55
 Re: OT: Street Rod Speedometer in reply to Jason1(Pa.), 05-11-2008 10:04:00
Dealer's parts man used to ask you the tire size and give you the right gear. Easy enough then.
dave guest
05-11-2008 19:43:45
Bernie Steffen
05-11-2008 18:32:39
Could go to larger diameter rear tires. Bernie Steffen
low budget
05-11-2008 14:58:28
Leave it the way it is. It will look more impressive to a passenger. As long as you know how far off it is, you can avoid tickets.
big fred
05-11-2008 13:14:00
If it's an aftermarket speedo, your best bet is to contact the company that made it. Tell them your tire size, rear end ratio and transmission type, and they should be able to point you in the right direction.
jdemaris
05-11-2008 11:32:13
Here's a more specific link for speedo correction stuff:
http://www.transmissionsone.com/speedometer_gear.htm
jdemaris
05-11-2008 10:54:44
You don't need to change gears unless it winds up being the cheapest/easiest fix. There are all kinds of "correction" gearboxes for mechancial speedos - and also electronic correction boxes for electronic speedos. Some companies use them as original equipment - like Dodge diesel trucks.
I just put a different one on my truck to because it was off by 9%. You can calculate exactly what you need - and the little gearbox hooks between your trans speedo cable.
Many places sell them - one is:
http://www.transmissioncenter.net/727Transmission.htm
Bob
05-11-2008 10:12:11
It would help to know WHAT you have...
If it is a mechanical speedometer, you can change the speedometer drive gear(s) in the transmission, or there are speedometer drive adapter gearboxes with different available gear ratios to correct the error.
If it is an electronic speedometer, there are electronic units available to make the correction (DRAC's)
Jason1(Pa.)
05-11-2008 10:28:05
 Re: OT: Street Rod Speedometer in reply to Bob, 05-11-2008 10:12:11
Sorry. I didn't say that it is a mechanical speedometer. Where would be the best place to look into for new gear(s)? thank you
Gerald J.
05-11-2008 10:38:21
 Re: OT: Street Rod Speedometer in reply to Jason1(Pa.), 05-11-2008 10:28:05
First you have to find out what driven gear you have. And who made the transmission where that gear rides. Then you have to do the math to find out how many more teeth you need. Then you can start with the parts room at the nearest dealer for the make of transmission. Sometimes its hard to get enough teeth on the driven gear and you have to change the driver and the driven. I know Ford parts counters have a book of speedometer gears.
I changed my F-150 from 3.08 to 4.10 gears. It had an 18 tooth driven gear, and I computed I needed a 24 tooth driven gear for the same driver. I had to go to a couple dealers who customized Mustangs to find a 23 tooth driven gear (6 months later truck and it would have been a computer setting). Since the teeth on that gear are very thin, I bought a spare. So far in 80,000 miles I've not needed the spare.
It should be that hot rod shops that sell rear axle gears carried the speedometer gears, but I've not found that to be the case.
Gerald J.
Bob
05-11-2008 10:35:53
What is the transmission make???
Knowing that, GOOGLE speedometer gears (make).
Pudd Diddly
05-11-2008 10:55:38
 Re: OT: Street Rod Speedometer in reply to Bob, 05-11-2008 10:35:53
I'm sure there are more places out there, but this one poped up when I googled.
Link
