Re: Leaky Hydraulic Pump?
Posted by Bob M on February 27, 2001 at 06:49:45 from (192.232.119.194):
In Reply to: Leaky Hydraulic Pump? posted by Jeff on February 26, 2001 at 21:01:23:
Sounds like you've got a slow leak on the live pump output shaft seal. It's a good idea to renew both seals on the pump while you've got it off.
Removing the pump without disturbing the timing is straight forward: Mark on the distributor housing the location of the #1 cyl plug wire tower, then remove the distributor cap. Now turn the crankshaft by hand until the dist rotor is lined up with the mark you made on the dist housing, AND the TDC notch in the fan pulley is aligned with the pointer on the timing gear cover. The motor's now at TDC #1 cyl firing.
Remove the hose manifold from the hyd pump and swing it aside, and remove the primary wire from the coil. You can now unbolt the pump/distributor assembly and pull it off the motor.
To reinstall the pump simply reverse the above steps. Make sure that when the pump is back in place the dist rotor is again aligned with the mark you made on the dist housing. And DO NOT crank the motor with the pump removed - otherwise you'll have to find #1 TDC again.
Post A Followup
: Re: Re: Leaky Hydraulic Pump?
Today's Featured Article - Memories of an IH Super A When I was ? up to 10, I worked on my Papaw's farm in Greeneville, TN every summer. As I grew older (7), it was the thrill of my day to ride or drive on the tractor. My Papaw had a 1954 IH Super A that he bought to replace a Cub. My Papaw raised "baccer" (tobacco) and corn with the Super A, but the fondest memory was of the sawmill. He owned a small sawmill for sawing "baccer" sticks. The Super A was the powerplant. When I was old enough (7 or 8), I would get up early and be dressed to ... [Read Article]
Latest Ad: Variable pulley for case 1530 skid loader [More Ads]
