Re: Breaking Hydraulic Pump Shafts
Posted by Haas on April 28, 2001 at 17:53:58 from (129.37.117.77):
In Reply to: Breaking Hydraulic Pump Shafts posted by Mike on April 28, 2001 at 06:25:06:
I don't know anything about your tractor, etc. And maybe the other posts are your solution. However, it sounds to me like your problem could be misalignment of the shafts and couplings. If you have a rigid coupling in the shaft and things aren't lined up perfectly, it will cause the shaft to flex every revolution and eventually break due to fatigue. Solution is to make sure all is in perfect alignment. A pump with a larger diameter shaft will help. Of course if you are overloading because of pressure relief problems none of this applies.
Post A Followup
: Re: Re: Breaking Hydraulic Pump Shafts
Today's Featured Article - An AC Model M Crawler - by Anthony West. Neil Atkins is a man in his late thirties, a mild and patient character who talks fondly of his farming heritage. He farms around a hundred and fifty acres of arable land, in a village called Southam, located just outside Leamington Spa in Warwickshire. The soil is a rich dark brown and is well looked after. unlike some areas in the midlands it is also fairly flat, broken only by hedgerows and the occasional valley and brook. A copse of wildbreaking silver birch and oak trees surround the top si ... [Read Article]
Latest Ad: Variable pulley for case 1530 skid loader [More Ads]
