Re: Re: Re: Re: Re: Re: Farmall C Tricycle Front End Question???
Posted by Haas on May 07, 2001 at 19:42:18 from (205.188.193.151):
In Reply to: Re: Re: Re: Re: Re: Farmall C Tricycle Front End Question??? posted by Fatback on May 07, 2001 at 12:20:39:
There should be four stud bolts that screw into the rear four holes of the plate that has the 6 holes. The post with the wheels then fastens to those studs. The front two holes are for a tow bar or other implement attachement that may need to hook on the the steering mechanism. The tilt is toward the rear of the tractor. That is to give it a little caster action so the wheels will turn back straight ahead due to the motion of the tractor.
Post A Followup
: Re: Re: Re: Re: Re: Re: Re: Farmall C Tricycle Front End Question???
Today's Featured Article - Memories of an IH Super A When I was ? up to 10, I worked on my Papaw's farm in Greeneville, TN every summer. As I grew older (7), it was the thrill of my day to ride or drive on the tractor. My Papaw had a 1954 IH Super A that he bought to replace a Cub. My Papaw raised "baccer" (tobacco) and corn with the Super A, but the fondest memory was of the sawmill. He owned a small sawmill for sawing "baccer" sticks. The Super A was the powerplant. When I was old enough (7 or 8), I would get up early and be dressed to ... [Read Article]
Latest Ad: Variable pulley for case 1530 skid loader [More Ads]
