Farmall Tractors Discussion Board
Re: Engine Sleeves
Posted by Roger on February 27, 1999 at 07:58:10:
In Reply to: Engine Sleeves posted by Roger on February 24, 1999 at 17:28:22:
Yesterday I talked to the service manager at the local Case IH dealer about the sleeves and how much they should stick up. He says that the sleeve only needs to stick up enough so that you can catch your fingernail on the edge (probably only a few thousandths). The .040" must have had something to do with the old gaskets they used.
Roger
Post a Followup
: Re: Re: Engine Sleeves
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
