Re: What Year/Model is this engine ?
Posted by Hugh MacKay on March 12, 2007 at 05:34:07 from (209.226.247.175):
In Reply to: What Year/Model is this engine ? posted by CSR on March 12, 2007 at 03:20:47:
CSR: The block part number 366204 R1 indicates it came from a Farmall 130. Could be 230, I'm not sure if they used the same number. 100 and 200 used the same block part number 354898 R3 and SA after serial number 310000 plus all SC used 354898 R1.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
