Re: What Is Draft Control?
Posted by wkw on March 12, 2007 at 12:51:53 from (129.128.46.173):
In Reply to: Re: What Is Draft Control? posted by georgeky on March 11, 2007 at 20:59:54:
I believe I have draft control on my B414. I know on mine there are the words "deeper" with an arrow. I am assuming that I move forward the lever the deeper my 3 pt. implement is into the ground? My draft control lever moves when I move the 3 pt lever - I never know what the position of the draft control lever is supposed to be when I am working with my rear blade or work my chain harrows. Can someone explain, and it will have to be very simplistic for me to understand, what i should be doing with the draft control lever position relative to the 3 pt lever when working with various implements.
Looking forward to all your great information.
Ken
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
