Re: What Is Draft Control?
Posted by L Mack on March 12, 2007 at 14:05:36 from (68.157.139.93):
In Reply to: Re: What Is Draft Control? posted by wkw on March 12, 2007 at 12:51:53:
wkw, If the draft lever moves when your lift lever moves, it is from friction between the concentric shafts. The draft lever should not move with your lift lever. For the implements you mentioned, you do not need true draft control. You can control the depth on the fly using the depth lever. The only implements that I was ever able to get the draft control to work on was a Pittsburg Frame Cultivator with a B414 or a Ford Dexter. Heavier work such as disking or plowing would wreck the draft control in short order in my experience. Basically, the deeper or lower you set the draft lever, the deeper the implement should work with the depth lever set to the same point. For the work you are doing, I would simply turn the draft control off and go with touch control. I do not remember how to do that on the B414.
Home
| Forums
Today's Featured Article -
The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac.
... [Read Article]
Latest Ad:
1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
