Re: 140 adj. breaker point screw
Posted by Nawlens_Gator on June 10, 2007 at 13:42:20 from (68.155.114.225):
In Reply to: 140 adj. breaker point screw posted by hogsbackfarm on June 10, 2007 at 05:22:03:
Your right. I noticed we have opposite opinions about electronic ignition. I switched out 2 tractors to electronic ignition but at the same time switched to alternators and the flame thrower coils. I've got less than 6 months on them and all I can say is they start and run much better. I'll maybe change my mind when one of the electronic ignitions fail, or maybe I should just buy a spare. If they last at least a few years I'll never go back to points. I appreciate your sharing that you've seen them fail. I wasn't aware of that.
Notice if the poster had electronic ignition he wouldn't be looking to replace a screw right about now.
Has anyone else had electronic ignition failures on their tractors? I'd be curious to know the approximate mean time to failures.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
