Re: 140 adj. breaker point screw
Posted by georgeky on June 10, 2007 at 20:50:47 from (205.188.116.138):
In Reply to: Re: 140 adj. breaker point screw posted by Hugh MacKay on June 10, 2007 at 17:12:59:
Hugh, I tend to agree about the electronic ignition. I have had several go bad on trucks. I have never had any trouble with the factory set up on these Farmalls. They have worked fine for generations.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
