Re: SMTA pto?
Posted by Dan on March 02, 2002 at 18:48:24 from (12.18.158.25):
In Reply to: SMTA pto? posted by Danm on March 02, 2002 at 10:10:23:
I have an SMTA. Last summer while baling the PTO suddenly quit, no noise or anything. Turned out it was the seasonal disconnect coupling. Apparently it is not uncommon for those to go bad when they get worn a bit. I am going to replace it with a solid coupler but have to split it to do it. I have been told also to let pto run when not using it. Apparently otherwise the apparatus in the rear really spins when it it off.
Post A Followup
: Re: Re: SMTA pto?
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
