Re: Save Me From Selling My 300U (or worse)!!
Posted by MARK on July 14, 2002 at 19:15:52 from (209.209.135.1):
In Reply to: Save Me From Selling My 300U (or worse)!! posted by gerald on July 11, 2002 at 04:49:34:
I,TOO,HAVE A 300U.IT STARTED FOULING PLUGS AT ONE AFTER A PERIOD OF LOW USE.IT TURNED OUT TO HAVE A CLOGGED PASSAGE IN THE CARB. THIS PASSAGE IS SO TINY I COULD NOT SEE IT THE FIRST TIME I HAD THE CARB APART.I ATTEMPED TO BLOW AIR THRU IT,BUT FINALLY POKED A TINY WIRE THRU IT AND THEN BLEW IT OUT.IF I REMEMBER CORRECTLY,IT MAINLY FOULED THE NO. 2&3 CENTER PLUGS.SINCE THEN I PUT OVER 1000 HRS ON IT AND MAYBE 2 SETS OF PLUGS.(STILL ORIGIONAL 6 VOLT SYSTEM TOO)
GOOD LUCK-HOPE THIS HELPS.
MARK
Post A Followup
: Re: Re: Save Me From Selling My 300U (or worse)!!
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
