Re: belly mower on C
Posted by MNBill on August 29, 2002 at 08:52:44 from (206.10.38.128):
In Reply to: belly mower on C posted by mwkellner on August 29, 2002 at 07:04:52:
I have a Farmall H with a 6 ft Artsway midmount finish mower and I'm very happy with it. I mow about 7 acres a week with it and it cuts really nice. You will need to get very quick on the clutch when turing to keep the mower blades going or make wide sweeping turns without using the clutch. I can take it off and put it on by myself but I really have to grunt. It's much easier with two people. Hopefully this fall I can get the 52 Super C running so I can put the mower on it (its a little smaller tractor).
Post A Followup
: Re: Re: belly mower on C
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
