Re: Re: M jumping time
Posted by Old Hand on November 12, 2002 at 05:46:43 from (152.163.189.203):
In Reply to: Re: M jumping time posted by Gomer on November 11, 2002 at 16:16:05:
The drive gear may be worn out. To check this remove cap mark position of rotor remove adjusting clamp and pull distribitor out. There will be driven gear on end of distribitor shaft and drive gear inside drive housing. If these are bad Your local IH dealer should have them they are not cheep though. This assumes you have original type IH distribitor.
Post A Followup
: Re: Re: Re: M jumping time
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
