Re: power steering problems
Posted by Martin Caldwell on December 20, 2002 at 13:26:50 from (152.163.189.203):
In Reply to: power steering problems posted by Bryce Andreasen on December 19, 2002 at 19:29:14:
I had the same problem with a 450. It probably the flow divider valve that is bad. I tried erplacing it with a used one but it had the same effect. If you have tried to buy one they can't be found. I ended up plumping a regular flow divider into the system. Now, everthing works.
Post A Followup
: Re: Re: power steering problems
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
