Re: IH464 / D179 inframe, is rear main bearing accessible?
Posted by Bernard le mécano on January 22, 2003 at 19:26:48 from (142.169.58.161):
In Reply to: IH464 / D179 inframe, is rear main bearing accessible? posted by TX Ted on January 21, 2003 at 19:36:35:
The aluminium plate hold the oil seal and there have two 5/16 bolts to remove, for remove the cap. You dont have the choice to split the tractor and remove the flyweel.
bernard le mécano QC Canada
Post A Followup
: Re: Re: IH464 / D179 inframe, is rear main bearing accessible?
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
