Re: wheel weights- steel vs liquid
Posted by Haas on January 27, 2003 at 19:55:15 from (166.72.245.61):
In Reply to: wheel weights- steel vs liquid posted by Gary- The Rookie Farmer on January 27, 2003 at 18:04:00:
Practically all farm tractors have solution in the tires these days. It's an easy and cheap way to add weight. Sometimes alcohol solution is used instead of calcium chloride. You don't have the corrosion problem with the alcohol. As far as the result, there would be no difference between adding the solution, or equal weight with the wheel weights. However, you will have to add 3 or 4 weights to each wheel on your H to get the same weight as filling the tires 75 percent with liquid. Also, depending on what you are planning to do with your H, you may not need the extra weight. If it's just a show or parade tractor, just use air in the tires. If just mowing or something like that and not heavy draft work like plowing or disking, you won't need the weight. The weight does lower the center of gravity and makes the tractor a little more stable on slopes.
Home
| Forums
Today's Featured Article -
Memories of an IH Super A When I was ? up to 10, I worked on my Papaw's farm in Greeneville, TN every summer. As I grew older (7), it was the thrill of my day to ride or drive on the tractor. My Papaw had a 1954 IH Super A that he bought to replace a Cub. My Papaw raised "baccer" (tobacco) and corn with the Super A, but the fondest memory was of the sawmill. He owned a small sawmill for sawing "baccer" sticks. The Super A was the powerplant. When I was old enough (7 or 8), I would get up early and be dressed to
... [Read Article]
Latest Ad:
Variable pulley for case 1530 skid loader
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
