Farmall Tractors Discussion Board
Re: Farmall 560 PTO help
Posted by Farm-Al on September 09, 1999 at 19:41:15 from (152.163.204.188):
In Reply to: Farmall 560 PTO help posted by Lloyd on September 09, 1999 at 17:28:26:
Loyd- The 560 had an early pto that was A planetary type. It was basically the same as the 450. This would't hold up under the added load of A sheller attachment on the 2MH PICKER AND also I'm sure, outher heavy loads.The later 560's had A over-center pto clutch. You didn't indicate which pto you have. If it's the early one it may need band adjustment. If it's the later one adjustment may not help, may have warped discs,which can cause it not to turn in the off. position.
Post a Followup
: Re: Re: Farmall 560 PTO help
Today's Featured Article - An AC Model M Crawler - by Anthony West. Neil Atkins is a man in his late thirties, a mild and patient character who talks fondly of his farming heritage. He farms around a hundred and fifty acres of arable land, in a village called Southam, located just outside Leamington Spa in Warwickshire. The soil is a rich dark brown and is well looked after. unlike some areas in the midlands it is also fairly flat, broken only by hedgerows and the occasional valley and brook. A copse of wildbreaking silver birch and oak trees surround the top si ... [Read Article]
Latest Ad: Variable pulley for case 1530 skid loader [More Ads]
