Re: I-4 or W-4 shift pattern
Posted by 49 Cubber! on May 05, 2003 at 03:55:11 from (206.74.216.60):
In Reply to: I-4 or W-4 shift pattern posted by Mark W on May 04, 2003 at 20:21:44:
Keep in mind that on the I-4,someone may disagree with me but on the ones Ive had and seen,that second and third gears have been switched but the decal still showed the same normal gear pattern.Second will be faster than third.
Post A Followup
: Re: Re: I-4 or W-4 shift pattern
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
