Re: Whats the correct way to turn off an MD?
Posted by Bill on June 19, 2003 at 09:54:19 from (12.36.152.153):
In Reply to: Whats the correct way to turn off an MD? posted by andy on June 19, 2003 at 09:34:12:
I can tell you what the manual says Andy.
Let the engine cool at idle on diesel for awhile. Give it time to stabalize.
Then, switch the engine over to gas before shutting it down. They say to reverse the starting procedure.
I have a 450D, and when I try it this way, most of the time it dies when going from diesel to gas.
I think the main thing when shutting it down is to let it idle and cool off before shutting it down.
Then, after stopping the engine make sure you have the compression lever in the gas position so the valves will not warp.
I do not know if this is correct or not, but we have had the 450D since 58 and never cracked a head or warped a valve.
Best of luck,
Bill
Post A Followup
: Re: Re: Whats the correct way to turn off an MD?
Today's Featured Article - An AC Model M Crawler - by Anthony West. Neil Atkins is a man in his late thirties, a mild and patient character who talks fondly of his farming heritage. He farms around a hundred and fifty acres of arable land, in a village called Southam, located just outside Leamington Spa in Warwickshire. The soil is a rich dark brown and is well looked after. unlike some areas in the midlands it is also fairly flat, broken only by hedgerows and the occasional valley and brook. A copse of wildbreaking silver birch and oak trees surround the top si ... [Read Article]
Latest Ad: Variable pulley for case 1530 skid loader [More Ads]
