Re: In search of Tie Rod Assemblies
Posted by got done with my 560 sett on December 08, 2003 at 16:07:27 from (198.68.173.133):
In Reply to: In search of Tie Rod Assemblies posted by Chris C. on December 08, 2003 at 08:32:28:
told you I would post back. Well one I had to heat and throw in the bucket 3 times and then it came apart easily. I wire brushed it and oiled it with the oil can and it worked just fine. The other one was a different story. While removing it on the outside the ball poped thru the casting and I had to buy the piece with the nothches cut in it for adjustments. I went to the caseIH dealer and the IH partsman there walked back and got it off the counter and handed it to me. I said charge it cause I need it and do not want to know the price. I figured it was 40 to 50 dollars but I run 5 tractors and need this one tomorrow. At least it is ready for morning.
Post A Followup
: Re: Re: In search of Tie Rod Assemblies
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
