Re: Covered grease zerks
Posted by Jon on December 15, 2003 at 06:09:57 from (172.209.185.47):
In Reply to: Covered grease zerks posted by Nebraska Cowman on December 15, 2003 at 02:45:42:
The covered zerk is for the water pump shaft and should be greased every 10 hours, and the uncovered zerk is for the water pump bearing and should be greased every 60 hours. Maybe the cap is there to help differentiate between the two?
Post A Followup
: Re: Re: Covered grease zerks
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
