Re: Re: Re: Duals for M
Posted by Bill Smith on January 04, 2004 at 13:22:31 from (63.147.130.101):
In Reply to: Re: Re: Duals for M posted by rustyfarmall on January 04, 2004 at 12:26:24:
I always considered a 50 horse power tractor boarder line for actually utulizing the floatational use of duals for pulling. In the right senerio as you are discribing (discing on loose dirt which would be on already disced or plowed ground) the duals would probably help. Having the wide front instead of the tricycle would probably help just as much. Not to many people trying to make a living working ground with an M as one of there main tractors today, compared to the 60's when the M was likely a number 2 tractor in the tractor line-up on a functional farm. Put the duals on if you want. If I have to mess with duals on an M, I am just going to walk over and get on the 1066.
Post A Followup
: Re: Re: Re: Re: Duals for M
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
