IHC 354 brakes - leaking shaft seals
Posted by SgtStew on March 17, 2004 at 18:24:15 from (209.247.222.84):
I have new brake disks ready to install, but now notice that the existing disks and wedges are oily. I would expect that this has been the source of my insufficient brake problem; leakage from the shaft seals that has saturated the disk material. Question: can these leaking seals be replaced from the outside of the case, or do I have a major task ahead of me? Can someone kindly "splain" what I need to do.
Post a Followup
: Re: IHC 354 brakes - leaking shaft seals
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
