Re: Oil Analysis, what's it got in it now?
Posted by 49 Cubber! on May 06, 2004 at 10:58:13 from (206.74.216.53):
In Reply to: Oil Analysis, what's it got in it now? posted by Jrod on May 06, 2004 at 09:00:41:
I bought an old A once that was pretty dirty on the inside of the engine.I cleaned out what I could from the opil pan and valve cover and changed the oil useing non detergent,I substituded one quart for detergent,next oil change two and so on until i was at full detergent oil.Each time running about 50 hrs between each change and new filters each time.This allowed the remaining sludge I couldnt get it to brreak down slowly instead of big chunks and cloging everything up.Worked good.It broke a cam tooth and jumped timing nad when I pulled the front cover off it was pretty clean.When I pulled the valve cover it wasnt shine new looking but it was a heck of alot cleaner than when I first took it off.
Post a Followup
: Re: Re: Oil Analysis, what's it got in it now?
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
