Re: Ok I'm done. I need one of you wiring gurus
Posted by Bob on July 30, 2004 at 08:22:41 from (66.163.134.177):
In Reply to: Re: Ok I'm done. I need one of you wiring gurus posted by DANWV on July 30, 2004 at 07:47:31:
Many digital meters will not work around engine electrical systems because the RF noise given off by the ignition system and the charging system gives their digital guts a headache. This has been brought up several times on this board and the FORD board.
Either use an EXPENSIVE digital meter that can tolerate the ruckus, or get an analog meter. Even a cheapy analog meter will probably work better around engine electricals than a mid-priced digital.
Is your regulator grounded? If it mounts directly, is there clean metal for it to ground to through the mounting pads? If the regulator mounts on rubber grommets for vibration elimination, there will be a ground strap or pigtail that bridges across from the regulator frame to one of the mounting bolts to provide a good ground to the regulator.
Post a Followup
Subject:
Today's Featured Article - An AC Model M Crawler - by Anthony West. Neil Atkins is a man in his late thirties, a mild and patient character who talks fondly of his farming heritage. He farms around a hundred and fifty acres of arable land, in a village called Southam, located just outside Leamington Spa in Warwickshire. The soil is a rich dark brown and is well looked after. unlike some areas in the midlands it is also fairly flat, broken only by hedgerows and the occasional valley and brook. A copse of wildbreaking silver birch and oak trees surround the top si ... [Read Article]
Latest Ad: Variable pulley for case 1530 skid loader [More Ads]
