Re: Ok I'm done. I need one of you wiring gurus
Posted by lee on July 30, 2004 at 10:26:21 from (24.24.95.246):
In Reply to: Ok I'm done. I need one of you wiring gurus posted by DANWV on July 29, 2004 at 21:28:18:
I bought a re-built generator from a tractor supply with a new regulator. You would think it would be a no brainer and expect problem resolved.
I had a new bat on the tractor. I had re-wired my charging circuit. It was simple and correct. No charge. I took the gen/reg to an old timers Starter/Gen/Alt repair shop. He went thru and cleaned up the gen commutator and adjusted the brushes. He adjusted the regulator to the gen on his tester. He ran it under load for 20 minutes. Final output was 7.5V and 20 amps on his tester. The thing I liked was I now knew I had a good unit. Charge was $20. I bolted it on and problem resolved. Another suggestion might be to re-wire your chgarging circuit with new wire and soldered connectors. If you still have the old wiring and connectors you may not have a good solid circuit. Old wiring may wring out as OK for volts and ohms on any single wire and yet fail to carry the current properly under load. I agree you may have damaged the reg with wiring reversed. Your bat should be replaced with a known good bat or a new bat. If you take your unit to a shop you can hold on bat replacement. If the shop tested unit doesn't work it's your wiring or bat.
Post a Followup
Subject:
Today's Featured Article - Memories of an IH Super A When I was ? up to 10, I worked on my Papaw's farm in Greeneville, TN every summer. As I grew older (7), it was the thrill of my day to ride or drive on the tractor. My Papaw had a 1954 IH Super A that he bought to replace a Cub. My Papaw raised "baccer" (tobacco) and corn with the Super A, but the fondest memory was of the sawmill. He owned a small sawmill for sawing "baccer" sticks. The Super A was the powerplant. When I was old enough (7 or 8), I would get up early and be dressed to ... [Read Article]
Latest Ad: Variable pulley for case 1530 skid loader [More Ads]
