Re: Couple of questions regarding 766 farmall
Posted by CEB on September 28, 2004 at 07:40:37 from (199.141.125.33):
In Reply to: Re: Couple of questions regarding 766 farmall posted by RANDYMES on September 27, 2004 at 17:28:41:
Randy,
Sleeve O-rings tend to eventually deteriorate over time. How many hours are on the tractor? Water would have to get in the oil if this was the problem. Since the O-rings are on the bottom of the sleeves, if they leak, it goes directly into the oil pan. Keep checking the oil level.
Post a Followup
Subject:
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
