Re: Couple of questions regarding 766 farmall
Posted by Aces on September 28, 2004 at 10:46:23 from (67.0.21.199):
In Reply to: Couple of questions regarding 766 farmall posted by RANDYMES on September 27, 2004 at 16:46:17:
Randy One way you can tell if it is steam warm it up good and hold your hand in the blow by BE Careful if it is steam it will be hot as steam would be if it is just blow by it will not be to hot to hold your hand in it. The seals are the thing I don't like about wet sleves but the dry sleve engines will not take the power and heat as wet sleves. I under stand the new over the road trucks are up to 50 pounds of boost on the intake a dry sleve engine would over heat.
Post a Followup
Subject:
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
