Re: Grease Points
Posted by rustyfarmall on October 05, 2004 at 17:51:11 from (216.248.75.173):
In Reply to: Re: Grease Points posted by Andrew Betzner on October 05, 2004 at 17:35:35:
Let me think on that, if it's an early H, there will be one on the PTO, one on top of each rear axle, one on top the steering shaft just forward of the steering wheel, another on the steering u-joint under the hood plus one on the bushing where the shaft goes through, one on each end of the clutch shaft, one on the water pump(one or two shots here), and one on the front of the tractor. I think that's nine if I counted right. Yours may not have one on the PTO, but you may have two on the water pump.
Post a Followup
Subject:
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
