Re: Cotter Pin questions and How to figure tire si
Posted by captaink on October 07, 2004 at 09:41:49 from (66.115.214.56):
In Reply to: Cotter Pin questions and How to figure tire size posted by Al Fitch on October 07, 2004 at 07:36:03:
Cotter pin bending depends on your personality. Normally, I bend the long one just enough to keep the pin in the hole. That way if I ever need to get it out and reuse it (and I’m in the middle of Tim-Buck-Too) it is less likely to break and remain useable. But, if I foresee a situation where there may be a chance of something getting caught on it, I develop my uncle’s personality which is to bend both sides opposite ways and tuck them in as tight to the shaft as possible. Normally this really ticks me off as it makes it very hard to work with them, almost impossible to get them straight again, and makes them very susceptible to breaking when visiting Tim-Buck-Too and an emergency arises.
Bottom line is to use your common sense. There is really no wrong way to bend a cotter pin unless it falls out or gets hooked on someone or something.
Post a Followup
Subject:
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
