Re: Cotter Pin questions and How to figure tire si
Posted by El Toro on October 07, 2004 at 14:25:45 from (64.12.117.22):
In Reply to: Cotter Pin questions and How to figure tire size posted by Al Fitch on October 07, 2004 at 07:36:03:
Hi Al, I always bend the cotter pins in both directions around the pin, bolt or axle that uses cotter pins. I use a big safety clip to secure
my plow,since I have to remove it from the tractor. I also use it when I attached an implement to the drawbar. Hal
Post a Followup
Subject:
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
