Re: 140 into an A
Posted by Hugh MacKay on January 11, 2005 at 04:37:19 from (209.226.247.68):
In Reply to: 140 into an A posted by rick in sc on January 10, 2005 at 17:40:06:
Rick: The engine will bolt right up with no problem. You will probably need to do some modification on coupling the radiator. The A and SA had no water pump. Water pump on 100 and 130 basically covered the bottom end of water jacket, and that was a relatively easy change over. The 140 however has water pump on the fan hub. That may make it a bit more difficult. May also make it easier.
I have a SA and 140, will compare later today, and let you know what obstacials I see. In the meantime you may hear from someone who has tried or done this change. I will get back this evening, with my opinion.
Post a Followup
Subject:
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
