Re: CUB/MAGNETO INSANITY
Posted by Farmalldan on February 07, 2005 at 09:51:26 from (64.154.26.250):
In Reply to: CUB/MAGNETO INSANITY posted by DANFROMKY on February 07, 2005 at 09:41:51:
Dan,
You cannot check magneto timing with a timing light. Once the impulse disengages, full advance is achieved. (Well, actually, if you made a timing mark for full advance, you could use it to set timing with a light.) You need to set static timing per the manual and then you'll be good to go.
Farmalldan
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
