Re: CUB/MAGNETO INSANITY
Posted by Bob on February 07, 2005 at 14:59:03 from (66.163.134.177):
In Reply to: CUB/MAGNETO INSANITY posted by DANFROMKY on February 07, 2005 at 09:41:51:
When you rotate the engine slowly by hand, the magneto impulse will trip at TDC. If it is set to trip any great amount earlier than TDC, there is a risk of kickback while cranking. As soon as the engine "catches" and speeds up to over a couple hundred RPM's, the impulse no longer "catches", and the timing jumps to full advanced running timing. The actual amount of advance is determined by the IMPULSE LAG ANGLE, usually marked on the impulse, and selected by the tractor manufacturer, and it does vary. The actual advance is the impulse lag angle doubled, as the mag turns 1/2 crankshaft speed. A typical lag angle might be 14 degrees, which would give you a running timing advance of 28 degrees. That is why the timing mark intended for "static" timing, by slowly rotating the engine until the mag "snaps" is not lined up when viewing it with the timing light... it is then at full-advanced running timing. I don't know what the impulse lag angle spec is for a CUB, offhand, but the Fairbanks mag (as far as I know) is NOT original equipment. If you know the flywheel diameter, you can determine the circumference, and divide that by 360 degreee, which will tell you how far the running spark is actually advanced for each inch it's off the static TDC mark.
Home
| Forums
Today's Featured Article -
The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac.
... [Read Article]
Latest Ad:
1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
