Re: CUB/MAGNETO INSANITY
Posted by Bus Driver on February 07, 2005 at 16:20:03 from (66.226.36.68):
In Reply to: CUB/MAGNETO INSANITY posted by DANFROMKY on February 07, 2005 at 09:41:51:
Some cubs have two timing marks on the front crank pulley. As the marks come by the pointer, the first mark is the full advance mark, the second (close behind the first) is TDC. Contrary to some other posts, using timing light will determine if advance is occurring with both mag and distributor even if only 1 mark is on the pulley. When advanced, the light will flash before the TDC mark gets to the pointer.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
