Re: Temperature gauge reading low?
Posted by CNKS on March 25, 2005 at 18:17:56 from (204.249.178.138):
In Reply to: Temperature gauge reading low? posted by Nathan in Texas on March 25, 2005 at 07:28:06:
While I agree with the others about the cold running unless they are worked hard, toss your gauge, bite the bullet and get a new one. Provided you have a pressurized system, the temp will exceed 212 or in your case 205 degress at the edge of the red. If you had 200 degree water and the gauge is at the bottom of the run position, it is simply wrong.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
