Re: Steering U-joint
Posted by r4etired on April 27, 2005 at 18:18:12 from (64.12.117.13):
In Reply to: Re: Steering U-joint posted by RustyFarmall on April 27, 2005 at 14:53:39:
I have used several aftermarket U joints, I use 5/16 roll pins with a smaller size pounded inside the 5/16. personally trust them more than bolts. They fit tighter than any bolt will so you get the original play that starts the wear
Post a Followup
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
