Duh! Need to check both petcocks
Posted by Dick Davis on May 26, 2005 at 01:35:39 from (64.12.117.13):
My favorite M started blowing major blue smoke. A neighbor suggested that one or more rings may have failed and I would be wise to check the engine oil for gas content. When I drained the oil into an empty 5 gallon pail it overflowed! No wonder for the blue smoke the engine was full of oil and hydraulic fluid. I was in the habit of pre operation oil check by opening only the lower petcock. Had I opened both petcocks I might have figured out there was something amiss!
Question is how hard is the front seal of an M &W distributor driven hydraulic pump to change? Any way I can screw it up? Thanks for any suggestions. Dick Davis
Post a Followup
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
