Re: SUPER C STARTER PROBLEM - NEED HELP.
Posted by farmallhal on August 29, 2005 at 15:54:16 from (64.24.35.16):
In Reply to: Re: SUPER C STARTER PROBLEM - NEED HELP. posted by DCTX on August 29, 2005 at 08:20:30:
Thanks for your response. Have you previously removed a starter from a fast hitch Super C with the auxillary valve attached to the right side of the Touch Control unit? This valve is right behind the starter and there is not even a 1/2" of clearence. There just isn't a lot of possible movement to the rear. I'm guessing the starter has a "snoot" like my M which I had out not long ago. Maybe once it is unbolted from the frame there is some movement away from the engine which would clear the aux. valve when moved toward the rear of the tractor for removal. I'm certainly hoping I don't have to remove some of the hydraulics to get it out. Just trying to know what I'm up against before turning some wrenches.
The starter is not locked to the flywheel as I can very easily hand crank start the tractor. I'm certain it is either the switch or starter motor. Thanks for your post and any other information you might have to share. Hal
Post a Followup
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
