140 front axle adjustment troubles
Posted by Dion on September 17, 2005 at 10:31:48 from (68.217.168.162):
I have installed a Woods L306A belly mower under my 140. Before installing the very expensive belt I took it for a test drive to make sure it rode correctly.
I found the front wheels hit the gage wheels of the mower. I cannot move the mower back or the belt will not be tight.
I have removed all of the clamps, pins and bolts from the axle, cleaned and lubricated the openings but cannot get the inner sleeves to move. This tractor was used to cultivate and was stored outside so there is a bit of rust.
My question is, how can I get the sleeves to pull out of the outer axle?
I have tried a come along and hammer but to no avail.
Post a Followup
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
