Re: Generator Problems '45 Farmall A
Posted by Jim Becker on October 08, 2005 at 19:28:38 from (71.96.28.154):
In Reply to: Generator Problems '45 Farmall A posted by thynes on October 08, 2005 at 14:09:53:
Since it has only a single coil, it is a cut-out, not a regulator. It has an F terminal but normally isn't used if you have a light switch. So the answer to your first question is correct and unused.
The three brush generator can put out a fairly high voltage if no load is connected. The 3-brush generators are inherently current limited, not voltage limited. It shouldn't put much out if the field isn't connected. If you have anything wrong with the generator, it may be that the field terminal is shorted, which I wouldn't worry about.
Post a Followup
Today's Featured Article - An AC Model M Crawler - by Anthony West. Neil Atkins is a man in his late thirties, a mild and patient character who talks fondly of his farming heritage. He farms around a hundred and fifty acres of arable land, in a village called Southam, located just outside Leamington Spa in Warwickshire. The soil is a rich dark brown and is well looked after. unlike some areas in the midlands it is also fairly flat, broken only by hedgerows and the occasional valley and brook. A copse of wildbreaking silver birch and oak trees surround the top si ... [Read Article]
Latest Ad: Variable pulley for case 1530 skid loader [More Ads]
