Re: Front Wheel Bearing Removal
Posted by old on January 02, 2006 at 19:07:58 from (207.69.139.137):
In Reply to: Front Wheel Bearing Removal posted by Joe/Mass on January 02, 2006 at 18:21:24:
Best place to buy any parts is Case/IH from there any good auto parts store should be able to get them. If you clean the hub up real good you should see 2 half moon sort of slots inside the hub for removel of the race.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
