Re: Front Wheel Bearing Removal
Posted by El Toro on January 03, 2006 at 03:35:11 from (64.12.117.13):
In Reply to: Front Wheel Bearing Removal posted by Joe/Mass on January 02, 2006 at 18:21:24:
You should be able to use a brass drift and drive them out using a hammer. Hal
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
