Re: Jacking up the front of an H
Posted by Elk Farmer on February 16, 2006 at 15:42:02 from (64.12.116.65):
In Reply to: Re: Jacking up the front of an H posted by danoh on February 16, 2006 at 13:56:13:
I can not start the tractor at this time. I have it tore down for painting. I do not have a barrel jack, will a 2 ton floor jack work? Where do you suggest I place the jack.
Thanks
Elk Farmer
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
