Re: H live hyd
Posted by Quebec Red on March 05, 2006 at 18:09:10 from (70.83.254.155):
In Reply to: H live hyd posted by garyj on March 05, 2006 at 17:54:42:
Short answer--YES-- . Now for the serious stuff. I did this trick 25 or more years ago. I had a scrapped 300. I took the front engine plate and timing gears (they are heavier) and away I went maybe some small details omitted, but you should change the gears as the H gears will fail if you use the hyds much (and you will). Makes the H a h-ll of a lot more useful and saves your leg and the clutch. ...QR..
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
