Re: popping
Posted by DelMN on March 13, 2006 at 11:30:15 from (170.153.65.23):
In Reply to: popping posted by randy on March 13, 2006 at 10:01:58:
Loose carbon in the cylinders can do the same. The carbon heats up to a glow and fires the fuel before and after when it should. Spraying water into the carb while running will usually rid this problem. It is simple to try before going any further.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
