Re: Crank bearing caps
Posted by Wayne Swenson on April 09, 2006 at 10:15:18 from (24.181.155.110):
In Reply to: Crank bearing caps posted by John London, Tx on April 09, 2006 at 05:08:42:
You MUST use the same bearing caps that came with the block because they are line-bored to size and cannot interchange with another engine or different bearing on the same block.
Connecting rod caps are the same. That is why they are numbered; so they can be put back where they belong.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
