Re: Couple Questions
Posted by Farmall43 on April 12, 2006 at 10:34:24 from (64.109.212.38):
In Reply to: Couple Questions posted by Jon Pando on April 12, 2006 at 10:08:21:
Check your tire air pressure. I don't really have any experience with the cubs but in the larger tractors I run about 13 psi in the rear and about 25 in the front. These tractors do not have any suspension so the tires have to take up the slack.. good luck and enjoy.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
